What are some great ways you've found to get a little greener when it comes to laser printers?
Here's a few tips to get us started:
■Use an eco-friendly font! Seriously, it works! The ink usage is lowest on Century Gothic, Ecofont and Times Roman.
■Recycle those cartridges. Refill your own if you've got a good set and can do it without too much mess, otherwise they end up in the landfill.
■Be sure your printer's Power Saver features are turned on - this not only helps to save the environment, but also can keep your power bill in check.
Rediscovered the Ecofont - remembered reading about it... 2 1/2 years ago. Forgot about it since then. :|
