Thank you!While this isn't a 38", it is a 34" Ultrawide with a 3440x1440 resolution and is highly rated for its price.
PCPartPicker Part List
Monitor: Gigabyte G34WQC 34.0" 3440x1440 144 Hz Curved Monitor (£379.00 @ Currys PC World)
Total: £379.00
Generated by PCPartPicker 2022-09-22 14:36 BST+0100
https://www.tomshardware.com/reviews/gigabyte-g34wqc
The Samsung Odyssey G5 is a 27" monitor instead of a 34" monitor. I can tell you that a 34" ultrawide is VERY nice. I have an ultrawide and the additional screen size is for sure worthwhile. You are basically able to get dual monitor setup without a bezel in the way. Also the Samsung Odyssey G5 is not rated as highly as the Gigabyte G34WQC so the extra money is worth the purchase.Thank you!
How about the Samsung Odyssey G5 ? Seems like it is the exact same as the Gigabyte one but a few quid less expensive.
The website I am on tells me that the G5 is a 34 inch monitor. So do 3 others... It is ultrawide too, maybe the contrast is just different?The Samsung Odyssey G5 is a 27" monitor instead of a 34" monitor. I can tell you that a 34" ultrawide is VERY nice. I have an ultrawide and the additional screen size is for sure worthwhile. You are basically able to get dual monitor setup without a bezel in the way. Also the Samsung Odyssey G5 is not rated as highly as the Gigabyte G34WQC so the extra money is worth the purchase.
AHHHHH OK yeah I see Samsung does have a 34" ultrawide version of that monitor. Most of the places I have seen only had the 27" 16:9 monitor shown. Overall the Gigabyte is slightly higher rated. https://www.rtings.com/monitor/tool...c34g55t/17023/22248?usage=3623&threshold=0.10 I would say the biggest differences come in how curved the display is, 1500R vs 1000R, and the HDR performance. My monitor has a 1500R curve and that is nice. I personally don't think I would want a 1000R curve as that would be VERY aggressive.The website I am on tells me that the G5 is a 34 inch monitor. So do 3 others... It is ultrawide too, maybe the contrast is just different?
Alright, thanks so much!AHHHHH OK yeah I see Samsung does have a 34" ultrawide version of that monitor. Most of the places I have seen only had the 27" 16:9 monitor shown. Overall the Gigabyte is slightly higher rated. https://www.rtings.com/monitor/tool...c34g55t/17023/22248?usage=3623&threshold=0.10 I would say the biggest differences come in how curved the display is, 1500R vs 1000R, and the HDR performance. My monitor has a 1500R curve and that is nice. I personally don't think I would want a 1000R curve as that would be VERY aggressive.
