Good Build Help
Paradocs
12
I will be gaming and streaming. I was thinking an i5 instead for the better gaming experience but will that effect the streaming and video rendering and editing aspect?
CPU: AMD FX-8320 3.5GHz 8-Core Processor ($149.99 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.99 @ NCIX US)
Motherboard: Asus M5A97 LE R2.0 ATX AM3+ Motherboard ($72.99 @ Newegg)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($79.98 @ OutletPC)
Storage: Sandisk ReadyCache 32GB 2.5" Solid State Disk ($39.99 @ Micro Center)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($57.98 @ OutletPC)
Video Card: MSI GeForce GTX 770 2GB Video Card ($319.99 @ Amazon)
Case: Antec One ATX Mid Tower Case ($34.99 @ NCIX US)
Power Supply: Corsair Builder 600W 80+ Bronze Certified ATX Power Supply ($49.99 @ Newegg)
Optical Drive: LG GH24NSB0 DVD/CD Writer ($15.99 @ Micro Center)
Total: $851.88
PCPartPicker part list: http://pcpartpicker.com/p/mNvrYJ
Price breakdown by merchant: http://pcpartpicker.com/p/mNvrYJ/by_merchant/
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor ($199.98 @ SuperBiiz)
Motherboard: ASRock H97M Micro ATX LGA1150 Motherboard ($75.66 @ Newegg)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory ($73.99 @ Newegg)
Storage: Crucial M500 120GB 2.5" Solid State Drive ($72.00 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($54.99 @ Newegg)
Video Card: Gigabyte Radeon R9 290 4GB WINDFORCE Video Card ($319.99 @ Newegg)
Case: Cooler Master N200 MicroATX Mid Tower Case ($39.99 @ Newegg)
Power Supply: Antec High Current Gamer 620W 80+ Bronze Certified...
That psu has got to go for sure. I would not bother with a 32GB ssd. What is your budget?
This would be a lot better for a tad cheaper.
PCPartPicker part list: http://pcpartpicker.com/p/4jGQf7
Price breakdown by merchant: http://pcpartpicker.com/p/4jGQf7/by_merchant/
Power Supply: Antec High Current Gamer 620W 80+ Bronze Certified Semi-Modular ATX Power Supply ($59.99 @ Newegg)
Optical Drive: LG GH24NSB0 DVD/CD Writer ($14.99 @ NCIX US)
Total: $828.58
A few notes on your build. swap out the antec one case for the cosair r200 or r300 case. the antec case has fixed lenth for gpu and a lot of the longer cards wont fit. the r200/r300 has the drive bays not there to block the long gpus. save up some money swap out the small ssd use a 120g-240g ssd has the main ssd for your main programs and games. i have 120g intel and with my 7zz sabertooth it takes about 10 sec from cold post to being in window 8. amd fx line is a dead cpu and mb combo. intel is also killing off the 1150 mb the next cpu in a few months on newer chipset is 1151 pins cpu. the haswell and the newer brodwell droping at the end of the year will run on the x97 chipset. the newer cpu will run ddr-4 ram.
i would also with a higher end gpu bump the power supply to a 750w unit. it not the total wattage it the 12v line that you want to have some head room. you dont want to run a power supply near it rated output n the 12v line.
My Budget is about $850 but im always looking for cheaper solutions. i will be playing a lot of games as well as downloading them because i do stream on twitch and will download the things people want to see. I need a good fast computer that has high quality gamingbut can also render videos and streaming
My build would do all of those things very well. Getting a ssd would be your first upgrade. I just can't recommend the 2 year old FXs anymore.
Does your build have those? im confused. is the build you gave me the upgraded good one
Does my build have what???
My build is stronger in the cpu and gpu department and it is also more reliable and future proof. The only thing my build really lacks is a ssd, but you couldn't fit it in your budget. That's why I said it would be the first upgrade you would want to make. Your need at the very least a 60-64GB ssd to put windows on, but I recommend a 120-128GB to be safe. 32GB is pretty much useless in a desktop environment unless you are dual-booting.
Could you add it into the build for me? that would be great
Total: $900.58
