Good cable management for non modular PSus
TheSpartaGod
16
I have a corsair VS 550 non-modular psu and i need help with cable managements. I saw my cables in a jumbled mess on the mid section of the case. I am using a corsair carbide spec-01 case which has a nice amount of cable holes. I really would like to upgrade to a bigger GPU in the future so i need this mess of cables out of the way.
The case:
Does the case have openings on the back for you to route your cables ? Those always help. Also use zipties to tie up and lose cables and if possible you can tie or place the cables in that black square are where your CD Drive and other internal drives go! If you want a bigger GPU in the future you should look for a bigger case. Reminder : You can't go wrong getting a bigger case if you got the space because their is no bottlenecking when you have more room for your hardware to breath.
