Good/Cheap Power supply for my pc
alfiee
Commendable
Jul 23, 2018
84
Hi, i've chosen all the parts for my pc but i'm struggling with choosing my power supply
the pc parts i chose are
GPU - GTX 1060 6GB
CPU - Ryzen 5 1600
Motherboard - AB350M pro4
Memory - G.skill Ripjaws V series 2x 4GB 3200 mhz DDR4
Storage - Western Digital 1tb hard drive
Kingston SSD 120gb
Case - NZXT S340
According to PCpartpicker these components will need atleast 282w to power the rig.
(Sorry if i messed up my english english isn't my native langauge.)
Yes, that will be enough and it is a really good PSU.
Seasonic gets my vote as well, I've owned 3 over the years and each one has been phenomenal (my current one being a prime titanium series). But they're not the cheapest. I understand the reason for most people wanting to save money on the PSU, but it's a critical component of your overall system and you never want to go too cheap.
Corsair also tends to get very high marks, but I have had no personal experience with them. They would likely be a little cheaper than the seasonic. If you're looking under $70, Corsair would be my choice then EVGA behind that. Anything under $30 I'd avoid, chances are it won't be name-brand and likely used cheap parts with potential of damaging your system.
Located in the netherlands and my budget is around 800 euros
The Bitfenix Whisper M 450 is a great PSU (quiet, modular, great performance and build quality) for €78: https://tweakers.net/pricewatch/651553/bitfenix-whisper-bwg450m.html
You can find the Bitfenix Formula 450, which is the same quality but non modular, for €62: https://tweakers.net/pricewatch/1112039/bitfenix-formula-gold-450w.html
Or the Seasonic Focus Gold 450 which is a little less quality (still pretty good. Based on the EVGA GS) and semi modular: https://tweakers.net/pricewatch/1117319/seasonic-focus-gold-450w.html
If none of those fit in your budget look for the be Quiet Pure Power 10 400w, Corsair CX450 or CX450M for ~€50.
