Good Cooling System?
amgraves08
23
Hey all,
I'm looking for a liquid cooling system for my build. Any recommendations? It needs to be AM3+ compatible, if that helps. Thanks for your help!
if your set on liquid the Corsair H100i is 79.99 after rebate on newegg which is a STEAL. Otherwise I would personally recommend a high quality air cooler for just the CPU, like the Noctua mentioned above or the high end Phanteks. That's just a personal preference though (if your case has the space for one). The liquid cooler will NOT be any quieter I can promise you that.
AIO liquid get the h100i. I've had the h80i and it was pretty much on par with my cooler master hyper 212 evo.
Or build a full custom loop for maximum performance. Challenging and lots of fun putting together.
It really all depends on what you wan't to spend and what you're actually using it for.
I don't want anything too expensive. Definitely under $100. But I also want to make sure I don't get any duds.
