Alright so I have a Intel i7-3770K in a Rosewill LINE-M Micro-Atx case and I'm having trouble deciding upon a good cpu cooler to get that would be great for overclocking and also fit in my case.
The i7-3770K has a base tdp of 77W at 3.90GHz, however in the BIOS even one step up to 4.00GHz changes the tdp to 180W, which is what a lot of good cpu coolers are marketed at. I can get it up to 4.50GHz in the BIOS, however it says that runs at a tdp of 220W.
Would it be adequate to get a 180W tdp cpu cooler such as the Hyper 212 Evo? Would that even fit in my case? Because I'm a little unsure of how to compare the dimensions between the cooler and the case. Would it also be unwise to overclock the i7 to over 4.00GHz with the Evo, therefore increasing the tdp reading in the BIOS to over 180W? Would a cpu cooler with a higher tdp be more suitable for better overclocking?
All in all I'm just a little bit confused about this whole ordeal, my only main concerns being that I can get a good cpu cooler that will both fit my case and allow for decent overclocking, that's all. If anyone has any good knowledge or suggestions on the matter I'd be really grateful for some advice
Here are my current specs:
Win7 64-bit
8GB RAM
240GB SSD
Intel i7-3770K
Intel LGA 1155 DZ75ML45K motherboard
EVGA Geforce GTX 970 SC ACX 2.0
EVGA 500w PSU
Win7 64-bit
8GB RAM
240GB SSD
Intel i7-3770K
EVGA 500w PSU
