G Goofy Goon Reputable Jul 4, 2014 7 0 4,510 Jul 4, 2014 #1 Hey! I'll be getting an FX8320+GTX770 will a XFX ProSeries 550W Bronze be enough to power these components in a gaming load?
popatim Titan Moderator Dec 2, 2009 39,136 1,041 136,890 Jul 4, 2014 #2 I would get a 650w if you had plans to overclock. Upvote 0 Downvote
coastie65 Splendid May 26, 2010 3,293 20 21,465 Jul 4, 2014 #3 Goofy Goon : Hey! I'll be getting an FX8320+GTX770 will a XFX ProSeries 550W Bronze be enough to power these components in a gaming load? It should be fine. Good choice. Upvote 0 Downvote
G Goofy Goon Reputable Jul 4, 2014 7 0 4,510 Jul 4, 2014 #4 popatim : I would get a 650w if you had plans to overclock. I will not be overclocking, but otherwise will it be fine? Upvote 0 Downvote
mickypheonix Honorable Mar 9, 2014 4,051 1 10,960 Jul 4, 2014 #5 Hi Goofy Goon The GeForce GTX 770 requires a psu with 42A on the +12v rail and a 600W PSU minimum although you xfx is a good psu i would suggest upgrading to this http://www.newegg.com/Product/Product.aspx?Item=N82E16817207014&cm_re=xfx_psu-_-17-207-014-_-Product this psu has 53A on the +12v rail and 650 watts , enough for your card and system Upvote 0 Downvote
G Goofy Goon Reputable Jul 4, 2014 7 0 4,510 Jul 4, 2014 #6 mickypheonix : Hi Goofy Goon The GeForce GTX 770 requires a psu with 42A on the +12v rail and a 600W PSU minimum although you xfx is a good psu i would suggest upgrading to this http://www.newegg.com/Product/Product.aspx?Item=N82E16817207014&cm_re=xfx_psu-_-17-207-014-_-Product this psu has 53A on the +12v rail and 650 watts , enough for your card and system The 550 watt has 53A aswell. I just read that the Amps are most important for a PSU and it's a quality PSU so i think i will be able to run it and game on it Upvote 0 Downvote
mickypheonix Honorable Mar 9, 2014 4,051 1 10,960 Jul 4, 2014 #7 you should be ok just you will have very little headroom Upvote 0 Downvote
G Goofy Goon Reputable Jul 4, 2014 7 0 4,510 Jul 4, 2014 #8 mickypheonix : you should be ok just you will have very little headroom I know but i will not be overclocking or upgrading in a long time. I'll get a new PSU if needed after some time. Upvote 0 Downvote
mickypheonix Honorable Mar 9, 2014 4,051 1 10,960 Jul 4, 2014 Solution #9 no probs , i hope it all works out for you Upvote 0 Downvote Solution
