Question Good Fan For Liquid Cooler Radiatior ?
Mar 2, 2019
62
What would be a good fan for liquid cooler radiator are there any good rgb ones? My setup has all rgb fans and my liquid cooler radiator fan is not the best and it is bright blue which doesn't match my other rgb fans
What is the make and model of your radiator? Are we dealing with an AIO or a custom watercooling loop? RGB fans require either an RGB enabled motherboard or connection to an RGB controller, if you didn't know, since that would mean having to find connections for the additional fans you're going to into your system on the radiator.
It is a kind of cheap uphere liquid cooler that I got for $40 and yes the rgb fans that I am using now are connected to a rgb controller didn't think of that would it just be better to get a fan that has no led or rgb ?
