Good graphics card for HP Compaq 6005 Pro Small Form Factor PC?
Jakirul
Hi, i've got a PC called HP Compaq 6005 Pro Small Form Factor PC which has
AMD Phenom II X B52 CPU
3.0GB DDR2 Ram
AMD Radeon HD4200 Integrated Graphics
500GB Hard Disk
DVD RAM Drive
240W PSU
I've been wanting to change the GPU but at the same time I don't want to change the PSU. Is there a good graphics card that can run games like Minecraft and also Photoshop at a reasonable speed without having to change the PSU?
It does i have the same mobo, I got the geforce 730 1gb ddr5 and its all compatible expect for the size the gpu its self is too long and tall to fit
One of the highly efficient Nvidia cards is really the only choice for a graphics card with gaming potential. The R9-250X (a re-branded HD 7770) entry level graphics card have a minimum system requirement of 450 watts. It would indeed require a PSU upgrade for the 240 watt PSU that you listed.
