Good PC build for 60fps 1080p Ultra Setting for most games?
NearWire
87
I'm looking for a good build that can
-Play most games a comfortable 60fps or preferably higher
-Run a comfortable 60fps on a 1080p screen
-A budget of 900$
-I don't need peripherals like keyboard, mouse, screen, etc.
-OS not needed either
-I do plan on recording, I'm willing to lower settings or res to 720p though when the situation calls for it. On that note, I do wish for the build to be suited for it.
I care most about performance for cheapest cost.
Went with a Xeon over a i5 because the Xeon has hyperthreading, which will help with streaming and editing.
CPU: Intel Xeon E3-1230 V2 3.3GHz Quad-Core Processor ($229.99 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($34.99 @ Amazon)
Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($129.99 @ Micro Center)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1333 Memory ($107.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($53.99 @ NCIX US)
Video Card: EVGA GeForce GTX 750 Ti 2GB Superclocked Video Card ($144.99 @ NCIX US)
Case: NZXT Phantom 530 (Black) ATX Full Tower Case ($103.99 @ NCIX US)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply ($44.99 @ NCIX US)
Optical Drive: Lite-On iHAS124-14 DVD/CD Writer ($14.98 @ Newegg)
Total: $865.90
Generated by PCPartPicker 2015-03-07 14:40 EST-0500
Get the i5. It will be plenty for streaming and recording. 8gb RAM is plenty too. Ge the bet GPU you can like the first build posted. a 750ti is not a good card for the machine. Spending money on high end motherboards/CPUcoolers/big old cases is pointless when the money would be better spent on a better GPU. I strongly recommend the first build and recommend against the second one.
PCPartPicker part list: http://pcpartpicker.com/p/yBKdwP
Price breakdown by merchant: http://pcpartpicker.com/p/yBKdwP/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($224.95 @ SuperBiiz)
Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard ($114.99 @ SuperBiiz)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory ($58.99 @ Newegg)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive ($51.88 @ NCIX US)
Video Card: Zotac GeForce GTX 970 4GB Video Card ($309.99 @ Amazon)
Case: Inwin G7 ATX Mid Tower Case ($44.99 @ Directron)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply ($56.99 @ NCIX US)
Total: $916.77
Generated by PCPartPicker 2015-03-07 14:52 EST-0500
This will give the best performance, I think a little to much was put towards the case considering the amount of extra power you can get in this with that money. You have an unlocked cpu, future SLI options(that will require a beefier psu then this) and an SSD.
Archgaull i'm sorry to say but that build is pretty awful, 750 ti is quite weak especially at this budget, I can understand why you choose 16gb ram but really the money is better spent elsewhere. I respect the xeon but why put a cpu cooler on a locked cpu? why Z77 and not a newer board it's not like that was any cheaper. The psu is fine but nothing better then fine.
And my last and final point, why 1/9th of the budget spent on the case?
I would be more in favour of the SSD over the overclocking, personal preferance there but I would find more performance in the SSD then in the extra few hundred mhz you get. I would have included one if it didn't go over budget but if op willing to go over a little it would be a great extra.
It could go down to a H81 board but you would lose the extra 2 ram slots which are nice for upgrade purposes.
Agree on that one😀
Really? I've been under the impression that OCing was the holy grail to FPS. Thanks for reply.
