Good quality PSU for my build?
Flyabout
9
I'm starting to build a pc as my old laptop is terrible, but I have no idea what Power Supply to get for the build I'm currently doing. Pcpartpicker recommends 237w but I'm too sure.
Current build: https://uk.pcpartpicker.com/user/flyabout/saved/#view=Pv3D4D
If anyone could give some good recommendations that aren't too expensive I would be very thankful.
Also if anyone could recommend any changes to my build it would be appreciated.
Perfect fit.
Power Supply: XFX ProSeries 450W 80+ Bronze Certified ATX Power Supply (£39.98 @ Novatech)
Total: £39.98
Generated...
you can go for any of the XFX series PSU's as they are all high quality, also you can look at the Corsair 430W CX PSU unlike most of the other CX series this one is actually very good quality, you should look at around the 400W mark just to give yourself some headroom for overclocking, if you want to upgrade in the Furture though you could look at the EVGA 550W G2 PSU as that's amazing.
Thanks I'll have a look at those
Perfect fit.
Total: £39.98
Generated by PCPartPicker 2015-11-16 14:55 GMT+0000
