Hello everyone--
So I have not built a gaming pc is a few years, so I wanted to double check to see if this is a good build and if it is even compatible (based off my research, I figured it was, but not sure LOL).
Case: Antec Nine Hundred Black Steel ATX Mid Tower Computer Case with Upgraded USB 3.0
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
Processor: AMD FX-8350 Vishera 4.0GHz (4.2GHz Turbo) Socket AM3+ 125W Eight-Core Desktop Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113284
Motherboard: ASUS SABERTOOTH 990FX R2.0 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131877
RAM: G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-1866C9D-16GXM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231615
GPU: SAPPHIRE 100352-3L Radeon HD 7950 3GB 384-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202026
PSU: CORSAIR HX Series HX750 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply New 4th Gen CPU Certified Haswell Ready
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
If you have any suggestions or what not, lemme know. Thanks!
