[SOLVED] Good wireless headset for PC and phone recommendation?
jason3893
15
I'm looking to upgrade my current headset.
Use-case:
  • PC and phone for videos and music mostly. Little bit of gaming.
Needed features:
  • wireless because I need to upgrade my phone soon and won't have a headphone jack after that.
  • wireless dongle to connect to my PC because my main PC does not have BT.
  • mic should be able to retract/fold away.
  • over-ear ear cups
  • volume control and mic mute control on headset
Budget:
  • $200 hard limit
Use-case:
Needed features:
  • over-ear ear cups
Budget:
  • $200 hard limit
Your needs are a bit at odds, a wireless dongle to the headset won't work with a phone, and if you don't have bluetooth then a bluetooth headset won't work on the computer. That is easily fixed though, simply get a bluetooth USB adapter for the computer...
Use-case:
Needed features:
  • over-ear ear cups
Budget:
  • $200 hard limit
Arctis Pro is good and has both bluetooth and a good transmitter for PC use but it's about $300.
Arctis 1 Wireless is 100 and has a USB dongle that looks to work for both PC and a phone (although not Apple it seems) https://www.amazon.com/SteelSeries-...pY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU&th=1
HyperX Cloud MIX has bluetooth and wired connection.
