Got ACER XC-605 case.Want to upgrade psu but not sure if ATX will fit
zaphyro
19
My pc is this model and case. Im happy with the chip and all but want to attach a Nividia gtx 750 ti to it. Only issue is that my psu is 240 and wont support it.i got another psu in mind which i linked at the end of the post and would also like to know if it would be able to run properly with a GTX 750 ti.
Another thing im worried about is that my case will not be able to use a standard ATX power supply. I linked the dimensions in the video below too.
My specs are:-
Proccesor-intel i5-4440
Graphics-integrated HD-4600(upgrading to gtx 750 ti)
Dimensions of case- 47.6 x 33.8 x 17.2 cm
RAM- 8gb DDR3 SDRAM
The Computer- http://www.amazon.co.uk/Acer-i5-4440-Integrated-Graphics-Windows/dp/B00L3EMSZ2
Also the psus im considering-
http://www.amazon.co.uk/Corsair-VS550-Plus-Power-Supply/dp/B00TE4XSMA/ref=sr_1_6?s=computers&ie=UTF8&qid=1440269538&sr=1-6&keywords=psu
http://www.amazon.co.uk/Corsair-Builder-Bronze-Power-Supply/dp/B009RMP14M/ref=sr_1_3?s=computers&ie=UTF8&qid=1440269538&sr=1-3&keywords=psu
which one is better. Thanks for the help!
Here is the best of TFX PSUs. Ones that will support a GTX 750 Ti. I doubt you'll find one with the mounting bolt pattern of your Acer. They all have the std. TFX bolt pattern, and slightly different dimensions. But you can check the measurements and see if they fit anyway, even if you can't get the mounting holes to line up.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&IsNodeId=1&N=100007657%2050001697%20600014004
I used SS-300TGW in a recent slimline build with this low profile GTX 750 Ti: http://www.newegg.com/Product/Product.aspx?Item=N82E16814125680&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Desktop+Graphics+Cards-_-N82E16814125680&gclid=CL7mnZXGvccCFYQ-aQodPZMI8Q&gclsrc=aw.ds
But you may have another issue. Since the case only has 2 expansion slots, it will depend on where the PCIe x16 slot is located and which way it faces. You may be limited to a single slot card. There are no GTX 750 Ti single slot cards.
What i think i might be able to do,correct me if i am wrong, is to get a new case, take the components and put them in it, get a new standard psu and then get the graphics card.
my budgets $200 so i should be able to get a decent psu for $50, a nice motherboard for $40 and the chip for $100. is that possible or am i not even able to change the case?
Yes, there's always that option. But you shouldn't have to buy a new board and CPU.
Dont think i have much choice though.zhould have thought ahead when i brought the pc :/ .thanks for the help clutch now all i neec to find out is if ghe motherboard is an oem of acer...
That depends. What board did Acer use? If it isn't a proprietary design and holds to the ATX/mATX/ITX std. it should swap over fine.
If they went and use some proprietary abomination, it might be tricky.
I did a bit of searching - Here is a low resolution photo of what is most likely his motherboard:
Model Number - AC82912
Look closely; the wifi adapter is above the PCI-E x1 slot. In my pic, the mini PCI-E slot is above that as well. Also, after looking closely the capacitor placements also match up, the PCI-E slot and PCB colors don't matter as OEM manufacturers often change them according to the supply.
If you do your part, and don't damage anything in the process of removing the drives and motherboard & IO shield... and reassembling in the new case, yes. Be sure to be careful for static discharge (ESD). Touch bare metal often while working with the parts to discharge yourself. Or better yet, wear a wrist strap.
That's fine. The IO shield is that sliver-looking plate that the input/output ports pass thru at the back of the computer. Where you plug in the monitor, USB stuff, etc. That rectangular plate pops out and installs in the new case. They come with the motherboard so they match up with the pattern of the rear ports.
OK. i dont think it will be too difficult as i dont have to install a cpu,ram or anything,just move it over since it was already done by the company.Any other tips you got for me because i dont think anythings left.Thanks for all the help clutchc and chayan1400^^
