Got an idea for a PC build and a few questions
neeeeeeeeeeeeerd
7
So, i'm thinking of building a new PC (saving up for it now) i got a budget of 1000 aud (around 800 usd).
Here's the Partpicker list https://au.pcpartpicker.com/list/qtd8pb it'll be used for gaming and other stuff.
i have 2 led fans but i only have 1 4 pin RGB header. Will i need to get a splitter for this???
Also, should i get a 120gb SSD and a cheaper ryzen CPU or should i get no ssd and get the 1500x???
If you can think of a better build that is under the 1000 aud budget pls use the Australian partpicker site. Thx in advance
I have made a lot of changes to the build. Let me say that there weren't any issues with your build.
So, to answer your questions.
Yes you'll need a splitter.
Stay with the single HDD for the moment until you can afford a 256GB or larger SSD.
Now for the list.
CPU: AMD - Ryzen 5 1500X 3.5GHz Quad-Core Processor ($238.00 @ Shopping Express)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard ($115.00 @ Scorptec)
Memory: G.Skill - FORTIS 16GB (2 x 8GB) DDR4-2133 Memory ($199.00 @ PLE Computers)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($60.00 @ Shopping Express)
Video Card: EVGA - GeForce GTX 1060 3GB 3GB GAMING Video Card ($295.00 @ Umart)
Case: Corsair - 100R ATX Mid Tower Case ($68.00 @ Shopping Express)
Power Supply: FSP Group - HEXA+ 500W ATX Power Supply ($55.00 @ Umart)
Total: $1030.00
Generated by PCPartPicker 2017-10-17 21:39 AEDT+1100
I did remove the fans from the list. Those can always be purchased later.
I doubled your RAM amount. That is what pushed the build slightly above your budget. I am hoping that is a soft budget. I realize I changed a lot and this build may not be for you. The changes made will offer better performance. The 1060 will offer that.
The best way to purchase RAM is in kits. There are plenty of questions here regarding mixing identical RAM and the user having issues with it. Most of the time it'll be fine but not always. Having a 16GB kit in play from the beginning removes the possibility of future RAM headaches.
You'll want to have at least 2666mhz ram with Ryzen. otherwise the cpu will be severely bottlenecked.
Yeah, i was thinking of getting 16 gb of ram but it put me over budget because RAM here is expensive.
I'm fine with a few $$ over budget so i think it'll be fine and if i have to i can just get the 1400 instead of the 1500x. A few more questions, is the mobo alright at overclocking? If it is i'll probably OC the ram or/and the CPU.
and will the computer be cool enough even with the 1 included case fan? thx
PS Is this build good too? (trying to use the same websites to reduce shipping fees) https://au.pcpartpicker.com/list/VTnHXH
