Hello,
First time building a PC and it wouldn't post. I then saw that some thermal paste spilled over 1 side of the CPU. I took it out and about 6-8 pins had thermal paste on it and there were some paste in the CPU sockets. I cleaned it using 99% Isopropyl Alcohol and a toothbrush the best I could. I could still see some very small specs of thermal base at the base of the CPU pins and small traces on the CPU socket which I can't get out.
However I tested it and now it posts successfully. Is there any possibility that I did any long term damage to my board and CPU?
It was a Ryzen 2400G CPU on a B450 board. Thermal paste I used came with the Hyper 212 LED cooler...from research it is not electrically conductive. I'm planning to run Prime95 for 12+ hours to test for system stability, if it works I guess I should be fine?
Man I feel like such a dumb ass. Watched so many videos before building and I still made a mistake that literally every video/guide warn about and wasted 9 hours diagnosing the issue...
Thanks in advance
Thanks in advance
