GoW- HELP!!!
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: alt.games.video.sony-playstation2 (More info?)
Okay, thanks to Ragemaster Randy, I was able to overcome a hurdle that
should've been a bump in the road... Now I need more help... I've come to
the point where I completed the task where I have to Open the Coffin and
jump towards
the dead body. Rip off the "Architect Son's Head" Key Item. Head down
the newly opened hole and make your way up the darkened and empty
hallway until a cutscene occurs. After the cutscene, continue through
and open the door. Welcome back to the Save Room.
At this point, the Jack Daniels has taken control.... I see the circular
room with the steam roller chasing me... but I'm stuck... can ya help me
out?
TIA!!!!
"Better to have it and not need it, than to need it and not have it."
> circular room with the steam roller chasing me... but I'm stuck...
> can ya help me out?
What exactly are you stuck with? The steamroller chase? You'll see a
staircase that you can go up about halfway around, and that should give you
an idea of where you need to go next. Hint: it's not the water. Second hint:
Best of luck doing it while drunk. I had enough trouble while sober. :)
-Z-
"Buckaroo Banzai" <blackhole34@yahoo.com> wrote in message
news:b4o5e.21111$zl.6335@newssvr13.news.prodigy.com...
> jump towards
> out?
> TIA!!!!
Buck,
I'm really worried about you, Buddy! You always post that you have a drink
in your hand. There's no shame in admitting you need help!
Anyway, about the game... as Zackman mentioned, there is a staircase you
have to crawl up on and then the trick is to jump on the roller and "ride"
it until you can hop onto the ladder on the other side.
Hope this helps and sober up!
Relz
