brodon Jun 3, 2021 4 1 15 Aug 2, 2021 #1 PI 4: with the x825 SSD SATA board using the 5v power and ground pinouts, how do I power the ICE COOLER which require the same two pins. . . . . ?? Thank you. . . . . . .
Solution A A Alabalcho Aug 4, 2021 Looking at that board' picture, the RPi pins are not used at all, so you should be able to power your cooler off them.
Lutfij Titan Moderator Oct 7, 2009 61,728 6,961 178,440 Aug 3, 2021 #2 I'm curious to know how many devices you've got occupying the 5v and ground pins on your Pi4? This pinpout diagram might help you out. Upvote 0 Downvote
A Alabalcho Titan Jan 13, 2011 14,016 433 81,090 Aug 4, 2021 Solution #3 Looking at that board' picture, the RPi pins are not used at all, so you should be able to power your cooler off them. Upvote 0 Downvote Solution
