Hi,
Today, I've installed 2TB Samsung F4 on rather old system (AMD nForce4 based), disk got recognized by the BIOS, Windows too... However, after choosing to initialize it as a GPT disk, and rebooting, PC wouldn't boot any more. New drive would still be recognized, but it just hangs at the IDE detection phase (it correctly displays all devices).
I hope I'm not posting on the wrong forum, but I got the idea that somehow choosing GPT instead of MBR cause the problem. I did try the disk on another computer (same chipset), and I got the same symptom. Also, I'm thinking, if it got recognized initially, without any partitions, and everything worked, it should rule out BIOS not supporting 2TB drive...
Disconnecting new drive solves the problem. Other drives are WD Blue 640GB. Same symptom if only Samsung is connected to the motherboard. If anyone has the idea regarding the issue I've described, or had a similar problem, please let me know. In the meantime, I'll try to connect the drive to P35 system and see what happens...
Thank you in advance
