Just purchased an EVGA 1060 6g single fan gpu and installed into a Corsair 200r case.
I have 2 front intake fans, 1 side intake, 2 top exhaust and 1rear exhaust. All fans are 120mm. I previously had a gtx 550ti with no side fan and no problems (70 max after hours gaming) but installed the side hoping to further cool the 1060.
My CPU is running max 45c under load and 25-27c at idle. No problem there. However, the gpu rockets to 80c within seconds, even in the start menu of a game. It doesn't go higher. I have Afterburner set to 80c.
I know 80c might be ok but I'm concerned about the huge discrepancy between the cpu and gpu (40c difference) and how fast it reaches it.
Should I change fan configuration? Replace thermal paste on gpu with mx-4? A pci cooler? Any suggestions would be greatly appreciated.
