Hello every one whos reading this so i got this big problem now. I have RX 460 nitro gpu i did unlock it with extra shaders everything was fine until recently i tought i will flash it to RX 560 bios so i tried first i flashed it to saphire single fan bios and my msi afterburner did not work(i couldnt set my temp limit, power limit, clock speeds and voltage) so i tought i will use THRIXX and Wattman but THRIXX did not work too and Wattman worked but fans didnt so i had to use msi afterburner for fans to work. But there were some glitches stuttering etc. and i tought ill try to use diffrent bios so i tried asus bios problems remain last of all i tried xfx bios but at some where around that time everything got really wrong. I opened gpu-z it couldnt read pixel filterrate and texture fillterrate and of course clock speeds. So i tought it will be driver problem i unistalled drivers with ddu and reinstalled them and used pixel patcher but problem remained so i tought ill just reflash to my stock bios and i did but the problems remained, i did everything driver reinstall, even tried to go back to RX 460 unlocked bios but same result. So i tought maby its windows problem. I reinstalled windows just one thing changed now i can use msi afterburner for voltage changes but nothing else, Wattman too same problem fans are not spinning and when i did use msi afterburner for fan use i tried to play games but now my temps are getting too high almost 90c even with fans spinning at 100% so when temps got past 85c i got crashes. Of course gpu-z still showing same thing no fillterrates and no clock speeds. I hope i havent damaged my gpu or sensors by any means with bios flashing, so if anything i just really hope i can fix this problem because i really dont want to buy a new gpu.
