If you look at my previous post, I am having some issues with my computer, that I suspect are due to the age of my GPU (nearly 2.5 years old, Zotac GeForce GTX960 4GB AMP!).
Along with this new issue presented, I was planning on upgrading anyways. I need a GPU within my price range, which is ~$250 max hopefully, and it should run my games better, the two most frequently played and most demanding being Tom Clancy's : Rainbow Six Siege and Rust. I also tend to record videos with ShadowPlay, so it would preferably be a Nvidia card.
I was thinking of getting a GTX 1060, but the 6GB is currently higher than my price range, so I want to know how much of a difference I would expect between the 3GB version and the 6GB version, as well as maybe my 960 if doable. If there are any other GPU recommendations better than the 1060 or equivalent but cheaper, please tell me.
Edit 1 : Also forgot to list my specs, not sure if it is needed, but figured I might as well list them.
CPU : AMD fx-8350 Black Vishera
GPU : Zotac GeForce GTX 960 4GB AMP!
RAM : 16GB DDR3
Motherboard : MSI 970 Gaming
HDD : 2TB Seagate Hybrid Drive
SSD : 500GB Samsung
Case : NZXT S340
if you also have a solution to my previous problem, please inform me
RAM : 16GB DDR3
SSD : 500GB Samsung
Case : NZXT S340
