Question GPU clock speed beyond measure ?
ridwan123
222
22
585
Last time i got an XFX RX 7900 XTX Magnetic Air and the clock speed during gaming shows 3000mhz but on the XFX website the maximum clock is about 2615. When i try to default to it with MSI Afterburner it still shows 3000mhz, and in the Afterburner during gaming the memory clock is 2487mhz.
is it the reason my card goes to warranty because it cant go to higher clock?
View: https://imgur.com/a/qJaZfFr
Update your post to include full system hardware specs and OS information.
Include PSU: make, model, wattage, age, condition (original to build, new, refurbished, used)?
Disk drive(s): make, model, capacity, how full?
List of all connected peripherals.
Wired or wireless network?
Gpu : Xfx rx 7900 xtx magnetic air
Cpu : AMD ryzen 7 9800x3d
Ram : 16×2 6000 mhz ddr 5 corsair vengeance
Mobo : asus prime x870 p wifi csm ddr 5
Cooler : deepcool le720 360mm
Psu : montech century 850w
This is either a bug on the software that reads the clock speed or you won the silicon lottery and got a gold sample that can boost that high.
If you don't see problems and the temperature doesn't go too high up, i don't see the problem. Its free performance.
You could undervolt it to make it run cooler or lower the power slider from the drivers to keep it from boosting so high if you are worried about it.. and if the number is not because of a bug. I had a case when HW info was showing my 7700X running at 11GHz which is obviously not possible.
