GPU cooling problems
halo3metallica
5
Hello everyone, I have a gtx 1080 ti plopped in a s340 case at the top pcie slot. I'm noticing an idle around 35 with a custom curve. Not too bad, but after reading around that under load it really shouldn't surpass 82 C I find my self at around 76 C in low graphics settings on certain games. I have a h110i with the fans in front of the radiator set to exhaust and the two case fans set to intake on the rear and top. I discovered one of my fans wasn't PWM and after changing that I've dropped about 3 degrees. However, this is still High. Looking for some suggestions.
Pictures would really help.
Normally you would want the exhaust through the top, or rear, for natural air flow.
http://imgbox.com/e0NE5nDY
http://imgbox.com/0D16sepo
The preffered configuration isn't an option with this case. There is a little piece for the wires that blocks the radiator from being directly in front of the case. I will try inverting all my fans though and seeing how that works
That's great!
So your temp is about 66 degrees now? That's decent I guess.
Larger fans will increase flow, and reduce sound. I do not know how large of an impact that will provide though.
I figure a larger exhaust fan on top wouldn't really help. But the back of the Case only supports a 120mm the top is currently a 120 but can be a 140. If that could get me cooler I'm willing to try it
