I have a asus sabertooth 990fx R 2.0 and have just switched to evga gtx 780 sli. Problem is the pci card slot is being covered. I'm using a m-audio delta 1010 lt so it has to be a pci slot. I tried a riser cable but it still would not let me install the graphics card it was really close though. I'm going for as cheap as possible anything to make it all work.
I don't know if there is a cheap thunderbolt solution that I'm missing or a pcie to pci chassis of some sort that isn't going to cripple the finances. I don't understand why they would design it this way? I could move the gpus to the x4 and x8 slot but that is pretty weak.
If anybody has anything for a fix I would be very grateful
I thank you all in advance for your time!
