Game - BF4
Res - 1080p
GPU usage spikes between 40-99%
CPU sits around 50%
FPS is spiking between 30-100fps
Precision X shows ZERO voltage?
I keep seeing a low fps (some maps it just its at 40fps) but nothing seems to be being stressed out? So what's causing it?
I figured assuming that the CPU can handle it, which I think mine can as its usage is 50% that if your asking a GPU to run full Ultra then it will do either of the following:
1. Struggle to run said game at a decent fps on Ultra therefore sit at 99% usage and produce poor fps.
2. Run said game fine with high fps and sit somewhere below 99% usage.
I seem to be seeing the opposite, my GPU seems to be spiking to low usage but also producing poor fps say 50% of the time, why is this?
Also the Voltage meter on Precision X just shows zero all the time?
As you can see below, my GPU usage rarely hits 99% even though the CPU stays around 50% and my fps still spikes quite low...
Res - 1080p
CPU sits around 50%
