I made this question in stackexchange, but, because it is moderated by trolls, my question was deleted "because I asked software recommendations", when clearly I was just suggesting possible solutions.
So I repeat the question here, and if there is a better web forum you can recommend me, I welcome your info.
My Nvidia GTX 670 died days ago, which means, it hangs and crashes, around log on time, when his drivers are installed.
I opened the card, and found a carpet of dust completely blocking the radiator, so it probably died out of heat. Cleaning it did nothing to fix the card.
But, it runs in safe mode, so I removed the drivers, (also tried other nvidia versions of the drivers), and now it runs as a "Standard VGA Graphics Adapter".
I can live with it, meanwhile I wait for a new card to arrive, but because I live in a very isolated place, it will take like a month until I get my new card.
The problem is that since it doesn't have any direct X support, my screen refreshes in like 5/10 fps with a lot of screen tearing, and the mouse cursor moves in jumps, scrolling excel is a torture, and youtube is a non starter.
Here is a screen capture of Dxdiag. It only says that the monitor is running at 1 hz (Which is clearly false), but I cannot check what is the actual speed of the monitor (A Samsung 2233 capable of 120 hz)
GPUz
DxDiag info
Monitor refresh rate
I have windows 7 64bit on an i7 920, so my question is: There is any way I can get better performance?
Maybe there are any 3rd party driver/video emulator, for generic VGA cards which would help to get better performance? (I have 4 processors and 8 threads for VGA emulation)
Maybe some memory module got damaged and can be diagnosed and disabled?
GPUz
DxDiag info
