GPU doesn't work after power outage
WarrXIII
After a power outage my pc didn't want to turn on. I narrowed the problem down to my GPU. With it plugged in, my pc doesn't switch on, but if I take it out and use my integrated graphics, it works. My GPU is a GTX 760 OC gaming edition. Its not under warranty anymore, because i sent it back to msi about 6 months ago and they replaced it (the problem was corrosion) I got it back 3 months ago, and now this happens. Is there a way I can diagnose and fix the problem myself? I've tried different cables, and still the same thing. I know it's not my motherboard because I originally thought it was that (one of the wires for my power button came loose and was shorting my system) and I sent my motherboard back and they tested it and there was nothing wrong, that's when I bread boarded my system and found out it was the gpu, and the on button.
You already diagnosed it, bad card. Without some electronics testing equipment and a lot of time you won't be able to find where the issue is specifically, and that is only if the issue is with a capacitor or some other measurable part. If it's an issue with the chip, you can't test that really.
If you want to replace it with the...
Yeah, I tested my system with a friend's psu, and I got him to try my gpu, but still nothing.
"still nothing" meaning your video card did not work in his system? Dead card then.
It didnt work. yeah, I guess the cards dead... Is there anyway I can diagnose and/or fix the problem myself?
If you want to replace it with the same speed card, the GTX 950 is pretty much exactly the same speed, at about $120. Or go with a GTX 1060 for a faster card at $200.
