GPU Driver Problem ..
Ultron-Evolution
32
Hi Everyone , I Need A Help On Drivers , Since Its A Laptop With A Dedicated GPU (AMD) Hp Gave Me A Disk For Drivers One Of Them Was My Radeon Graphic Card Driver Basically The Problem Is My Games And Web Detection Doesnt Detect My Amd Graphic Card Rather Then That They Does Detect My Intel GPU , Secondly No Updates Came From Hp About AMD Card So I Tried To Download From AMD Site It Worked But Still No Games Or Web Detection Detected It My AMD Card Is AMD Radeon HD 7670M Which I Cant Find On AMD Site It Always Install AMD Radeon HD 7600M Which Is Quite Less In Performance Than 7670M , The Driver Hp Gave Me Was Hd 7670M And Speecy Detects It And Shows me The Temprature But When I Uninstalled it And Install The One From AMD Site It Was (7600M) Speecy Doesnt Shows Me Temprature Nor Games Or Canyourunit.Com Detects it <<<--- This Is Web Detection , I Want A Driver From AMD Which Includes 7670M Not 7600M
Current Spec Of My Laptop :-
1)Intel Core i7 2.10 Ghz-3612QM- (4 Cores , 8 Logical Processors)
2)Ram 4 GB (2.5 GB Usable) (DDR3)
3)750 GB HardDrive (7500RPM)
4)Multiple GPU ( AMD Radeon HD Graphics 7670M ) - ( Intel HD Graphics 4000) ,
Total Available Memory : 4300 MB = 4.3 GB , Dedicated Video Memory : 2560 MB = 2.5 GB
5) System : Laptop 3rD Generation-HP , Windows-7 (X64) .
Refer To The Pictures :
1)http://postimg.org/image/6vm6zoxrr/
2)http://postimg.org/image/wd4ljafhz/
uninstall your installed amd drivers, then use this link to get the latest amd driver for your laptop (windows 7) http://support.amd.com/en-us/download/desktop?os=Windows+7+-+64
if games dont detect your amd card, check the catalyst control center for application settings and make sure games are set on high performance, if you did everything as i said, you should be working all good now and if websites detect your intel hd, its normal because intel displays image while amd powers it( for battery saving uses)
i hope i fixed you problem now
Disable the Intel integrated graphics in the BIOS options, save changes, exit BIOS, and reboot your system. Your laptop should now be defaulted to use the dedicated AMD graphics card and the Intel dedicated graphics should be disabled. This should resolve your issue.
I Dont See Any Option Disabling Intel HD Graphic Card In The Bios , Hence If Disable It In Device Manager , Then Catalyst Control Manager Says "Either The Device Has Failed To Detect System Or Amd Card Has been Disable From Device Manager. Well Thanks For The Fast Reply 😉
Manufacturer : HewlettPackard
ModelNumber : 2002-TX
Bios Version/Date : Insyde F.26 , 6/3/2014 And SMBIOS Version : 2.7 , Also I Am Hearing First Time That Bios Can Be Updated , If You Can Tell Me Where I Can Get The Latest Bios Version I Would Appriciate It :)
Thanks :) For Your Info I Will Search On It By The Way
I Did Uninstall Many Times And Tried To Install It Again And Again But Nothing Gained Well The Link You Gave I Already Had That Updated Driver , Also My Games Are Set To High Performance , Ya I See The Difference From Power Saving My Gta Iv Increased 20 Fps Turning It To High Performance , In Benchmark I Saw The Result And I Compared Power Saving With High Performance There Was A Major Difference But Still Gta Iv Shows Intel HD Graphics :\ And In Piriform Speecy When I Downgrade The Driver To The One Hp Recommend Me , Speecy Shows Me Temprature But When I Update It
To The Latest Driver From Amd Website It Doesn't Shows Me Temprature Of My Amd GPU Anymore :\ Also The One Hp Gave Me The Catalyst Install Manager It Had Driver 7670M , But When I Uninstall It And Update It From Amd Website It Turns To 7600M I Heared There's Alot Difference Between Them , Well Hp Didn't Solved My GPU Detection :\ It Only Does The Temprature Problem . I Want The Detection Problem To Be Solved , Also In Picture You Can See My Dedicated Memory Is 2.5 GB Which Is My AMD GPU Memory . And Other Is Intel Gpu .
Picture Link : http://postimg.org/image/eez7dbr6j/
