Recently, my GPU fan has suddenly gone to 3700 RPM, on boot, idling and gaming.
I used to use Afterburner to control it and it worked, i could control the fan speed, etc. about a week ago i turned my pc on and suddenly it went on full speed (100%) and when i use again afterburner to change the speed, nothing happens. I looked at speedfan and it says my gpu fan is running at 3700 RPM, and it stays there.
I have figured that there maybe something wrong with the fan, a loose wire, connection, the fan connector may be loose or something.
Just need a bit of advice of why it has happened and what the solution is. Thanks
