I am now on BIOS version F53.
CPU: Ryzen 7 3700x 8 core desktop processor
Motherboard: GA-A320M-S2H-CF
Ram: 2x8GB Micron branded, 3200 Mhz
SSD/HDD: Crucial P2 1TB 3D NAND NVMe PCIe M.2 SSD Up to 2400MB/s - CT1000P2SSD8
GPU: Radeon RX 5600 XT Powercolor
PSU: 1200w LEPA branded
G series power supply,
80 Plus Gold rating, model:
G1200-MA. Year released: 2013
Chassis: Thermaltake V200 Tempered Glass RGB Edition 12V MB Sync Capable ATX Mid-Tower Chassis with 3 120mm 12V RGB Fan + 1 Black 120mm Rear Fan Pre-Installed CA-1K8-00M1WN-01
OS: Windows 10 Pro, version
20H2 (OS Build 19042, 1052)
I have performed the reinstallation of drivers many times, all version 20.4.2. The game that needs this version of drivers is modded Minecraft, I use shader mods with the game that sometimes do not work properly or not at all unless it is on driver version 20.4.2.
Start Quote: "
Regarding shaders and AMD Radeon Drivers Certain AMD driver versions are known to cause crashes when using certain shaders. Your mileage may vary with these driver versions. I have tested every version since 20.4.2 up to 21.5.2, and the latest reliable/stable driver with shaders is 20.4.2. All later versions are known to cause crashes. I have also tested Radeon Pro drivers 20.Q3 and 20.Q4 and neither are stable.
To receive support from shader developers and other members of the community, please use Radeon Driver version 20.4.2, available from the link at the bottom of this message.
Update Regarding LWJGL Our good friend @Bálint has figured out the root cause of the issue, and has released a fix! I have verified this on driver 21.4.1. More information available at the linked message.
https://discord.com/channels/237199950235041794/237199950235041794/858737861042241556 Regarding Continuum RT and SEUS PTGI Continuum RT and
SEUS PTGI HRR2 both need newer versions of the driver to correctly function. I recommend
20.11.2. For these shaders, try this driver version if the above doesn't work. You may have some success with later drivers, but
if you face problems you must downgrade to 20.4.2 before you'll be helped. This applies to any AMD GPU supported by their drivers, starting with the Radeon HD 7700-7900 Series through to the RX 6000 series released in November 2020. I have a Radeon RX 5700 XT, on a B450 Motherboard with a 3700X
Download link: https://www.amd.com/en/support/kb/release-notes/rn-rad-win-20-4-2 psst, if you want to use a later driver, like if you want to run CRT or HRR2, if you have a shaderpack that crashes, switch to internal shaders before loading it. This has to be done every time you load it, so F3 + R (to reload shader) will still crash Also, starting with 21.2.3, some packs will refuse to load, such as Chocapic V9, while others have improved stability.
End Quote"
As with the Corsair Link 4 software, its the newest version, and I don't have any hardware associated with corsair, that might be the problem. whoops. I only got the software to see if it could control my GPU fans, I was just trying stuff.
