[SOLVED] GPU FAN making a noise - - - is it broken or is it coil whine ?
MrHar
20
Recently my gpu gtx1660ti 6g OC fan started making loud rattling noises when I speed my fan to 100%, which it doesnt usually do that, however it doesnt make that sound when its on 0% to 75% fan speed. Although, i did try to immediately speed up my fan speed from 0% to 80%, there it started making the noise, I also did it from 0% to 100%. but, if I slowly speed up my fan speed to 0% to 90% it doesnt make that noise.
Is it coil whine or my fan's bearing is loose. ( I dont know a lot about computers. I just searched some stuff up and came to this)
THANK YOU TO WHOEVER REPLIES!
EDIT:
I DONT USUALLY GO TO 100% FAN SPEED (ONLY IN 80% AND IN SOME CASES 90%) BECAUSE I ALWAYS LIMIT MY TEMPS IN MSI AFTER BURNER TO 75C AND 80C
NEVERMIND GUYS! I DIDNT REALIZE THAT MY POWER LIMIT WAS ON 125% FOR THE FAN AND WHEN I SET BACK TO 100% POWER LIMIT IT DOESNT MAKE THE NOISE ANYMORE.
i dont know how to delete this post, sorry.
Latest posts
