i got this gigabyte rx 580 and after some time , it noticed that the fan on the back starts making rattle noise . i check temps and they are in 71% at 100% load. the front fan is working perfectly but the 2nd one isnt. what happens at full load is that the front fan goes crazy speed and the back fan does the noise and spins slowly , i took the gpu off , pushed the fan a little bit backwards and when i plug it , the fan now spins a little then stop ,it repeats every 5 seconds .
what should i do , is there any simple fix?
should i unscrew the fan and oil it?
