My GPU fan has stopped spinning randomly and is out of warranty it makes very loud noises and the RPM drops frequently with the temps rising up to 95 degrees in games, the card is fine in itself. I’ve been trying to find a perfect fan replacement to fit into the card but I’m having so much trouble trying to get the right one,
I have the zotac GTX 960 mini 2GB
The fan size is 86mm with 40mm mounting holes, if someone could help me it would be a life saver until I get my new pc thank you!
I have tried two different fans, but none of them worked as they were wrong size and wrong connector, the current broken fan does disassemble from the heatsink and it is able to be changed
