Gpu fan slows down as temp gets over 60 degrees then stops eventually around 65 degrees, HELP!
Asil786
As i game my gpu handles the gaming and starts to heat up, but as it heats up the fan slows down hence, causing it to heat up to a point where the fan stops causing the heat to rise substantially and heat just causes games to lag and crash. i have a club-3d radeon hd 7750 1024mb GDDR5 PCI Express 3.0 gpu, i tried removing the fan and reinstalling, re applying thermal paste etc but didnt work, please help thanks.
Other pc specs
CPU- Intel i5-3570k
MOBO- Gigabyte ga-z77-d3h
RAM- Corsair 2x4gb 1600Mhz
PSU- Corsair cx600m
Case- zalman z12 plus
SSD- OCZ Agility 180gb
HDD- 1tb western digital
I have 2 120mm intake fans located at the bottom and front and 1 extractor/exhaust at the rear at the top,
what do you recommend me doing?
Hello man
Sounds like either a driver issue or a manufacturing issue. Un install the video card drivers and re-install them.
EDIT: Your PWM fan control is messed up.
Asil786
also, even in msi after burner it says fan will be spinning at x% but i can see its not moving at all?
Entomber
Admirable
Apr 21, 2014
2,752
409
PWM doesn't control GPU fans
do you have a GPU controller software like MSI Afterburner? You can use software like that to set your fan curve on your GPU so it doesnt' slow down under load.
Asil786
Even so, i have done this and fan still slows down at the temperatures specified, msi afterburner will say the fan is spinning at x% but in fact will be idle/not spinning at all.
Asil786
reinstalling the drivers did not work, still have the same problem?
Hello man
Yeah sounds like a driver issue, or the PWM control chip is broken. Try the driver removal using Driver Sweeper (easy way to clean everything out). If that fails then call the manufacturer.
Asil786
if i was to install an aftermarket gpu fan would that work? or will it be the same
Hello man
if its a driver/fan controller problem it will be the same.
