[SOLVED] GPU Fan Speed Fluctuating every ~30 secs or so during gaming
skeletorbro
24
Recently, I have been noticing an issue with my GPU (MSI RTX 2070 Gaming Z owned for ~2 years) where, when gaming, the fan speed will fluctuate (in RPM) after a certain amount of time. What's weird is that during this time the temperatures seem to stay pretty constant. You can see the fluctuations in this album, most of which seems to be isolated to fan one View: https://imgur.com/a/EwJTt7f
. I have tried to set a custom fan curve, but the issue still seems to be occurring.
I posted yesterday about another issue where my case fan leds have started appearing a lot dimmer. The person who helped me suggested it might be the PSU and I am wondering if this could possibly be related? The PC itself is about 6 years old so the PSU failing would make sense.
I have reached out to MSI regarding this and they asked me to try out a different card in the PCI slot but I don't have access to another card. I also haven't really removed the card all that often so I am unsure if this would be the issue.
Any ideas on what could be causing this?
My PSU dips voltage from 12V to 11.55V~ (which is kinda limit) and I can notice the fan speed being cogged down when the case fans are higher RPM (When i tried overclocking RX 580).
Issue is on your Graph I dont see max temp with the RPM, there might be target set in GPU if it reaches that Temperature, the fans go agressive.
Try to log it down soo (you see there Log to file) and upload it and link it here
Also check this one for target temp.
