I have been trying to fix my GPU fan speeds for awhile now and I wanted some help. I tried Asus GPU Tweak II but the fan speed would either not run at all (0 RPM) or do this:
0 RPM
1100 RPM
0 RPM
1100 RPM
constantly. This got very annoying and I uninstalled GPU Tweak and used Afterburner instead. I still can't get the fan speed to stop fluctuating, even with fan curve off and manual fan speed on at 25 percent.
Specs: PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor ($227.49 @ SuperBiiz)
Motherboard: MSI Z170-A PRO ATX LGA1151 Motherboard ($109.17 @ Jet)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory ($94.88 @ OutletPC)
Storage: ADATA Premier SP550 240GB 2.5" Solid State Drive ($60.99 @ Amazon)
Video Card: Asus GeForce GTX 1060 6GB 6GB Strix Video Card ($309.88 @ OutletPC)
Case: Fractal Design Define S w/Window ATX Mid Tower Case ($69.99 @ SuperBiiz)
Power Supply: Corsair RMx 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($109.99 @ Amazon)
Monitor: Asus VS247H-P 23.6" 1920x1080 Monitor ($109.99 @ Amazon)
Other: EK-XLC Predator 360 w/ QDC ($219.99)
Total: $1312.37
Generated by PCPartPicker 2016-12-11 10:42 EST-0500
Oh, and how can I set the fan speed BELOW 25 percent? Afterburner won't let me go below 25 percent.
EDIT: Setting it to 30 percent manually w/ no curve seems to fix the problem. However, I don't want it at 30 percent all the time.
0 RPM
1100 RPM
0 RPM
1100 RPM
Total: $1312.37
