Hi guys
I've got a gigabyte gtx 760 with a windforce cooler. The last couple of days the fans have been acting up. The fans are spinning to the max rpm even though the card is only at 30C and then after a few seconds they drop all the way down to 0 rpm for a few seconds and then this repeats. Sometimes the fans will stay extremely fast and loud for ages so it's very random, no distinct pattern. Adjusting the fan speed manually on MSI afterburner has no effect, nor does setting a custom fan curve. (However I was able to do this only a couple of days ago before this issue occurred).
Interestingly, MSI afterburner still thinks the fans are running at 20% even though the noise they make suggests that they are running much faster. This makes me think that it's possibly a problem with the card itself, or the BIOS? Does anyone have any suggestions or should I just wait for Black Friday and get a new card.
Thanks heaps
EDIT: forgot to mention that my case is very clean and dust free and I have uninstalled drivers (which didn't change anything) and also reinstalled the latest drivers. i have also rebooted the computer.
Other things I have done:
- Re-seated GPU
- Re-seated Ram
- Rebooted numerous times
- Uninstalled all overclocking software and removed my overclock (this did nothing)
- Flashed an updated BIOS onto the card, still the problem persists
So yeah nothing has worked so far.
Thanks heaps
- Re-seated GPU
- Re-seated Ram
