Are your Fans still set to auto?
Did you clean your PC recently?
Are you using MSI afterburner software to keep control of your Fan speed?
Yeah, I did last night. I was on vacation for a while so my PC was collecting a unhealthy amount of dust.
And no, I'm just using Asus GPU Tweak. I heard this kind of thing happens when one of the fans break.
well... you can always replace the Fan. I hope it is only the fan and its not a sensor that broke cause you will be having a bad time if its the sensor.
I'm still covered for warranty on the card, would replacing the fan be easier? Or should I just send it in just to be safe.
If the card is on warranty better not touch it. If you do that, they will null it because you...
If the card is on warranty better not touch it. If you do that, they will null it because you manipulated the card.
Send it to RMA.
Send it to RMA.
