Hi
I bought a used sapphire pulse 6800xt. Before I plugged it in I DDU wiped my PC, but the moment I switched it on the fans started howling (max RPM). Even after installing AMD drivers, using MSI afterburner and AMD software to try slow them down they are running at 106%/3500 rpm according to HW monitor. Temps when idle are around 30c
what I have tried:
what I have tried:
- reseated the GPU
- uninstalled and reinstalled MSI afterburner
- bios flashed the GPU
- updated the Motherboard Bios
- DDU wiped and reinstalled the drivers
- disassembled the GPU, cleaned, re-pasted and made sure the connector was properly plugged in. I might add the heatsink was dirty had a lot of corrosion but temps are really good
- swapped the PSU
- MSI MAG FORGE 100R Case
- AMD 9 5900x
- MSI tomahawk 570s wifi
- Corsair 32GB (4x8GB) DDR4 3600MHz
- Sapphire pulse 6800xt.
- MSI(MPG A750GF) 750W
