Question GPU fans come down very slowly despite temperatures being low
Techxz
75
So I bought a second hand SAPPHIRE PULSE ITX RX 570 4GB GPU (I don't know if it's been mined on or even have a custom bios flashed on to it) and it has this annoying issue where the fan speeds come down very slowly.
If the card undergoes load the temperature and fans stabilise at 78/79 degrees C and 3600RPM fan speed, but then as soon as the load is taken off the temperature goes down to 40 degrees C, but the fan speed is still very high. It then takes 10 minutes to drop down to 35 degrees C and 3000 RPM on the fans.
From a fresh boot and no load on the GPU the fan speeds are very low.
In the past, other cards that I've used have their fan speeds and temps drop at the same rate, but not this one for some reason.
List FULL PC specs. Which PSU are you using ?
1. "Complete" system specs should ALWAYS be accompanied with any driver, hardware, or performance question. Do not post DXDiag reports as they contain a TON of useless information. Posting a DxDiag in place of a System Spec List tends to ward off potential members from helping you.
Please supply the following system details/information:
(Complete System Specs)
-CPU make and model# (clock speed/voltage, type of cooler, and "Core" temperature @ idle and load)
-Motherboard make & model# (include Bios version if graphics card is not recognized or you are having stability issues)
-RAM (amount, clock speed, model#/link of kit, configuration)
-Graphics card(s) make and model# (clock speed, voltage if modified, Driver version and GPU temp both @ idle and load)
-Power supply make,model#, "AND" age (note if using 110V or 220V A/C input)
-HDD/SSD configuration (ie: Raid setup/ back up/ OS drive/etc..)
-Case/Chasis make,model# (fan make, model#, and configuration if having thermal issues)
-Operating System (If using Windows note Framework and service pack version)
-Monitor make, model#, and resolution (If model# is unknown list resolution and refresh rate)
*If the unit is a "laptop" or "All-in-one" system you must note the make and model# of the unit. Be sure you are ALWAYS using the OEM/manufacturer's Driver updates for the unit.
*If "Crashing":
-Note the nature of the "crash" in detail, as there are several definitions for the word "crash".
*If "performance" related issue:
-Note the "exact" point in which the performance reduction occurred (ie: After Windows update, After Bios update, After Driver update, After thermal system shutdown, After Hardware change/upgrade etc...)
*For diagnostic purposes please disable the following:
-Any/all Antivirus/ Anti-malware software
-Any/all OSD monitoring software
-ALL overclocks outside of factory spec
*If "Crashing":
A320m-s2h mobo
EVGA 500w PSU, but I don't see what that has to do with GPU curves?
