Hello i was trying to update my GPU firmware from gigabyte control center and every time it doesn't update it it just downloads it so I downloaded the firmware from gigabyte website and I opened switch installer for like 5 minutes. I thought it's not going to do anything because there wasn't any progress bar to tell you if it's 15% or 50% or 100% so I closed the switch installer then restarted pc to see if it had updated the gpu firmware, no it hadn't.
But the problem is that I have no gpu firmware now, literally no firmware.
Does anyone have solution?
- I tried restarting pc, didn't work.
- tried restarting gpu, didn't work.
- tried using fwupdater exe, it tells me "erase flash failed, reboot system to try again".
- I rebooted system, still not working.
