So I just moved to UK and I brought my pc with me. I used an adapter since you can't really connect an EU power outlet to a UK socket. Everything went fine for the first day, I played some Destiny 2 and Rainbow Six Siege as always. Then all of a sudden the computer restarts for no reason. I open the game and then the game crashes. I repeat the process and everytime the game would just crash. Then the game opens and 2 minutes in the computer completely shuts off. When I boot it up I noticed a white light above the GPUs power cables. I search it up and apparently it might be because the GPU is not getting enough power. So I bought a 850w power supply from gigabyte (I previously had a 750w PSU, which is more than enough for my specs, but it was 3 years old and I thought maybe its time has come). And since then I can't even open up the simplest of the games (Drift 86, Getting over it, Zuma) without the game crashing or the pc restarting. I monitored the temperatures of the GPU with MSI Afterburner and everytime it hits the 70 degrees mark the computer restarts. Sometimes it restarts right after i start the game. I took out the GPU, I cleaned it thoroughly and put it back. Changed the power cables, reinstalled the drivers, reset the entire computer and nothing has helped so far. Do I really need a new GPU?
RTX 2070
32 GB RAM DDR4 3200Mhz
Ryzen 7 3700x
B550 Tomohawk Motherboard
850w Gigabyte P850GM Gold
RTX 2070
Ryzen 7 3700x
