GPU Heat Issue
Tyler1811
9
PC SPECS:
GIGABYTE: GTX 660 OC
AMD fx8350 4.0Ghz
10 GB Ram
Idle Temp At Start 30 C
When Playing 90-100 C
After roughly 15-20 min of playing i get 15 FPS
And my Idle temp stays at 80C
Wont go down
GPU fans are working
And i use MSI Afterburner to check, NOT OVERCLOCKED AT ALL
This fixes when i do a PC restart and happens 20 minutes into being on again
Also, the PC runs good for 20 min, then FPS drops and Heat goes to 80 C and wont budge
vortical
492
This may seem overly obvious, but its better to say it now than have overlooked it. Make sure if you havent done so recently that you take a can of air and thoroughly spray out the heat sinks and make sure all GPU fans rotate freely
Tyler1811
9
I already checked, a dusted the fans and everything inside. Still happends
vortical
492
When you're at idle what does afterburner say your GPU usage is at?
Tyler1811
9
28
vortical
492
28% usage seems awfully high for idling but nothing that should cause 80c temps.
If thats the case you may well need to reseat the graphics cards heat sink or something else rather involved.
Tyler1811
9
Iv used a few torrents in the past, for the Forest. Idk if thats it, happend a few days after that torrent, If you can send me a thing to help me find and remove those
Load up task manager and look to see if the game exe is still running after you closed the game. Also there are other things that may still load the gpu without the user taking notice. There are rare instances of malware infecting some machines for Bitcoin mining.
