GPU heat issue
radinrahman26
12
Does amd radron rx 560 gpu have heat issues? If yes then....Two fans attached to it is enough? Or do i need better cooling system?
Ramlethal
Estimable
Dec 21, 2016
910
272
All Ati products tend to be way hotter than the Nvidia Products... Dont worry, they are actually like that. Unless it passes 90~100 Degrees... Try to never attach Fans to the GPUS... i could recommend searching for a Thermal Pad to lower its temperatures instead of the fans.
Ramlethal
Estimable
Dec 21, 2016
910
272
