Gpu Help please
James Wrigg
7
I have £200-250 to spend on a GPU upgrade ( For Gaming) Atm I run one Asus 7770 2gb Gddr5, 1920x1080 and I need some advice.
The cards I have considered are:
7770 2gb (Crossfire)
R9 280x 3gb
Gtx 760 4gb
Any other cards you can recommend please comment but also I need to know which would be the best from the 3.
Thanks for reading
James
yea get the gtx 770 2 gb. crossfiring would be a poor choice. A single card would be much better. Also 2 gb is enough for 1080p.
Just a side note: make sure you have a good psu. If it is not good enough, get the 760 and a new psu
