GPU help with a first time gaming rig builder!
12granb
76
Here's my current specs
MOBO- http://www.newegg.com/Product/Product.aspx?Item=N82E16813128529
CPU- http://www.newegg.com/Product/Product.aspx?Item=N82E16819103996
GPU- http://www.newegg.com/Product/Product.aspx?Item=N82E16814121475
PSU- Xtreme gear 500W PSU
HDD- 1TB Seagate Barracuda, and a 500GB Western Digital Caviar
OS- Windiws 7 home premium 64-bit
Now, what I want to get (PSU and GPU wise) is listed below
new GPU- http://www.newegg.com/Product/Product.aspx?Item=N82E16814150609
new PSU- http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021
Tell me, with a budget of 400 like i have, would this setup be okay for games like skyrim, BF3, Hitman, and the like? or will anything be conflicting with one another?
paddys09
858
I would definitely be useable and give decent performance, but if your budget is 400 you could do a lot better...
I think your over spending on the PSU, you won't need that much power and there are cheaper options......
With your budget you could stretch to a 7950/670, your CPU may hold you back a little with those cards, so maybe a 7870/660ti might be a smarter choice
djscribbles
1,212
The PSU is a good choice if you are considering crossfire in the future. Otherwise a 500W would be plenty.
This is a fantastic deal and would be fine for your system and allow you to get a larger GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817151119
and the review:
http://www.techpowerup.com/reviews/Seasonic/G550/11.html
For the gpu, you could fit in:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150590
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150605
(I stuck with XFX just in case you've got a preference, other brands may have better deals)
edit: I don't agree with 'planning' for CPU bottlenecking. The CPU may limit your card in some games, but in general, your GPU will limit your eye candy more often than not regardless of the CPU. If your CPU is going to bottleneck in a game, more GPU power may still allow higher AA settings, better textures, and other features without much impact to your frame rate, since these features don't add any extra work to the CPU.
paddys09
858
Ok well its worthwhile if you are going to crossfire... Although if you are not running in the sweet spot of your PSU , it just ends up costing you more on the electricity bill than it should as it isn't as efficient at converting to dc, but I suppose a couple hundred W isn't anything to be concerned about, go ahead if you feel you need to..
paddys09
858
Its worthwhile noting that not all the TX750's are modular, the one you linked for example isn't, and the ones that are... ie the TX750M is only semi modular
Apparently rosewills have gotten better, but still not what I would choose....I liked the look of the seasonic one djscribbles linked but I think it was only 550w...look to the AX series if you want a decent modular by corsair
12granb
76
the rosewill isnt good? :/ *** im confused. okay, i want the 7850, thats my choice lol, but as for PSU, i need a good, cheap, reliable, 600-700 watt psu. and my bbudget jsut dropped to 340 :/all in all, the rosewill and xfx 7850 with shipping and tax would be 330. so if you guys can find a good reliable and cheap 600-700 watt psu ill be set.
paddys09
858
Well, you can lower the wattage, you don't need 600-700W to be safe with your hardware, or lose the modular features but even then finding a decent 650W+ for less than $75 is a bit of a challenge
