My 9070 XT GPU will get stuck at PCIe 2.0 x16 speed at start up randomly, most of the time it will run fine at 4.0 speed but sometimes it will get stuck at 2.0 and wont go to 4.0 even when playing games
I thought it was a power saving feature but i literally disabled all pcie power saving features i could find, even went in bios and disable pspp policy. i manually set pcie speed to 4.0.
I disabled pcie express thing from the high performance power plan in Windows.
I saw a few people having the same problem and its on MSI motherboards so far, not the exact same motherboards but on msi motherboards in general.
I came here in hope there's some bug that can be solved. So far i didnt see anything posted in MSI forums about probably cause not many people care to check once in a while gpu z so they dont know its happening ( good for them i guess but im paranoic af)
I did a clean install as a last resort but didnt help.
PC Specs
Mobo: MSI Pro B650-S WiFi
CPU: Ryzen 7800X3D
GPU: 9070 XT
PSU: Gigabyte 850w Gold+
PC Specs
CPU: Ryzen 7800X3D
GPU: 9070 XT
