GPU is suddenly 100% load when idle HELP
Twistfaria
180
8
18,715
I have an AMD R9 390x recently I have been having an issue where it will spike up to 100% and start heating up when nothing taxing is happening. I've had this card for several months now with zero big problems until now. When this happens most of the time it will stay at 100% until I reboot my system. I haven't been able to tie it to any program or process so I'm unsure what could cause this.
I have tired:
>system scan with bitdefender it found nothing
>system scan with malwarebytes it too found nothing
>scan with hitmanpro all it found were tracking cookies
>I've rolled back to the 17.7.2 version of the AMD Radeon settings app.
>I've gone through and reduced the amount of services and startups that run.
>Gone through the uninstall repair of the alienware command center.
>I've checked in both techpowerups GPU-Z and MSI Afterburner to back up the numbers I'm seeing.
>I've downloaded process explorer and the highest processes on the GPU tab are dwm.exe and csrss.exe but neither seems to be using anywhere near as much as would be required to use 100% of my GPU.
>I've been dealing with this for a couple weeks now and I will think that I solved it but then it will start happening again. Yesterday I was also getting an error on startup from my Alienware Thermal Controller that said something long and confusing about the taskbaricon and throwing an exception so I repaired the alienware command center which has appeared to stop that error.
I'm not sure what else to try at this point and would really appreciate some help solving this issue!
System Specs:
Alienware Aurora R3
Windows 7
AMD R9 390x
Here is an image of both process explorer and gpu-z.
https://imgur.com/a/Iudas
What about putting it into a different computer and testing it out in that? Hopefully you have another computer you could test it in. Or like the other suggested do a fresh install of windows. Just an FYI I have installed the new Windows 10 Fall creator update on two different computers.. One was an inplace upgrade but I had to revert it back to windows 10 creator update (the one pre fall update that came out a few days ago). The other I did a fresh install of the Windwos 10 Fall update and that one works great. Reason I bring up that is the new fall update has in the task manager an GPU activity just like the CPU activity.. so you can easily check the activity with the GPU now.
Sadly I do not have another computer that I can put the card into. Even if I had another desktop in the house I doubt this behemoth would fit in it! Plus I have serious doubts that it is actually hardware related.
Are there any suggestions anyone can make other than a full windows reinstall? I have no interest in the many many many many hours it would take me to accomplish a full reinstall, with all the other software I would have to reinstall on top of that, unless there is absolutely NOTHING else I can try! (In case you are curious "programs and features" says I have 409 programs installed!)
I looked into yet more malware finders and downloaded and ran Spybot Search and Destroy. It actually found something that it labeled as "high risk". After it took care of it I didn't have the problem for...a little while. I was even able to hike the settings way up on the game I'm currently playing. However it was short lived as the GPU crashed after a few hours and then again would only show 100% load until I rebooted. I then ran Spybot again but it didn't find anything besides more tracking cookies. So I decided to totally uninstall the AMD software and reinstall it again. I have now done that but the problem persists. And now in addition to this issue I have had at least 2 BSODs during this whole thing as well. So I'm even more confused now as to what the heck is going on with my system. On top of that my Bitdefender software is now saying that its "services are not responding" and I have reinstalled it also to no effect.
Also the AMD software is incredibly unstable as just about every time I try and open it it either stops responding for several seconds or just plain crashes.
There was a psot not to long back, that had the same problem, and it was a GPU miner virus o nthere pc so i'd run a full system scan.
Edit:
I'd use multiple scanners, because this is not normal
